Převodovka 1.9 TDI 66KW
ZDRAVÍM KLUCI POTŘEBUJI PORADIT NA ME O1 MĚ NEJDE ŘADIT R.KDYŽ JI TAM ŘADÍM TAK TO JDE PŘES ZUBY A ŘAZENÍ JDE CELKOVĚ ZTUHA.POTŘEBUJI PORADIT CO S TÍM MÁM DĚLAT,JESTLI VÝMĚNA NEBO DOLITÍ.POPŘÍPADĚ CO TAM NALÍT ZA OLEJ,CENA A HLAVNĚ KUDY OLEJ VYPUSTIT A NALÍT ZPĚT.SORY JESTLI TO TU NĚKDE JE,ALE JÁ JSEM TO NENAŠEL.DÍKY ZA ODPOVĚDI
