JÁ JSEM MĚL PROBLÉM , ŽE MI AUTO PŘI ŘAZENÍ 3 STUPNĚ RYCHLOST 90 U 4 STUPNĚ RYCHLOST 105 A 5 STUPNĚ RYCHLOST KOLEM 120-125 PADALO DO NOUZOVÉHO PROVOZU. VYMĚNIL JSEM VÁHU VZDUCHU, VYČISTIL EGR VENTIL A JINÉ VĚCI A PAK JSEM TO DAL KAMARÁDOVI DO SERVISU A PO DVOU HODINÁCH MI VOLA, ŽE TO MÁM SPRAVENÝ A KDYŽ JSEM SE PTAL CO TOMU BYLO, TAK MI ŘEKL, ŽE BYL POVOLENÝ ŠROUB NA TURBU KTERÝ DRŽÍ TLAK VZDUCHU (ne podtlak). VYMĚNIL PODLOŽKY A TAKY PODTLAKOVOU HADIČKU, KTERÁ JDE OD TOHO A OD TÉ DOBY MÁM PO PROBLÉMU. NEVÍM JESTLI TI TATO INFORMACE POMŮŽE. SAMOZŘEJMĚ JSEM LAIK, TAKŽE SE ZEPTEJ AUTOMECHANIKA KDE TEN ŠROUB JE.
