bob130
1 -
bob130's Achievements
nejde mi klima o2 fsi 110kw / log z vcds:Wednesday,27,July,2016,22:47:44:62939 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: Release 12.12.0 (x64) Data version: 20130910 VIN: TMBBD61Z772054777 License Plate: Mileage: 201420km-125156mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77 VIN: TMBBD61Z772054777 Mileage: 201420km/125156miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: Sporadic communication error 1000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 06F 906 056 ER HW: Hardware No Component: MED9.5.10 G00 8219 Revision: --H03--- Serial number: SKZ7Z0F3813546 Coding: 0000072 Shop #: WSC 73430 790 00000 VCID: 7DF11F7F2404B5F6FF5-8028 2 Faults Found: 001669 - ECM Power Relay Control Circuit (J271) P0685 - 004 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0°C 049508 - No Communications with HVAC Control Module (J301) U0164 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 42.0°C Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0021122 Shop #: WSC 73430 790 00000 VCID: 73E539471240F386991-8026 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1Z0 907 044 J Component: ClimatronicPQ35 084 0305 Shop #: WSC 00000 000 00000 VCID: 3D71DF7F648475F6BF5-8068 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000004432081 Coding: 498C8F030004140000110D000000000000097F075C Shop #: WSC 20745 401 67465 VCID: 2B55E1278AF0EB46111-807E Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB Component: Wischer SK351 012 0401 Coding: 00063477 Shop #: WSC 20745 Subsystem 2 - Component: Fehler Lin-Slave 02 3 Faults Found: 02071 - Local Databus 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 235 Mileage: 201014 km Time Indication: 0 Freeze Frame: ON Voltage: 11.55 V ON ON OFF OFF OFF 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 5 Mileage: 201057 km Time Indication: 0 Freeze Frame: ON Voltage: 11.90 V ON ON OFF OFF OFF 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 123 Reset counter: 235 Mileage: 201014 km Time Indication: 0 Freeze Frame: ON Voltage: 11.55 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA Component: Q2 AIRBAG VW8 027 0900 Revision: 11027000 Serial number: 003B5D0ZXMLE Coding: 0020786 Shop #: WSC 73430 790 00000 VCID: 6BD521274A702B46511-803E Subsystem 1 - Serial number: 6332MSME13345D415 Subsystem 2 - Serial number: 6342MSME127C0C017 Subsystem 3 - Serial number: 6351HSME0B112526 Subsystem 4 - Serial number: 6361HSME0A6244453 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 8109E38FD8FC51161BD-80D4 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 842 B HW: 1Z0 920 842 B Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0F3813546 Coding: 0003101 Shop #: WSC 27162 260 69424 VCID: 3663C05341B2A6AE7EF-8063 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 2 Mileage: 201014 km Time Indication: 0 Date: 2000.00.00 Time: 18:10:00 ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb Part No SW: 1K0 907 530 H HW: 1K0 907 951 Component: J533__Gateway H12 0150 Revision: H12 Serial number: 31001068231465 Coding: 3D3F03C007001302 Shop #: WSC 73430 790 00000 VCID: 2C57E23B8FFEEC7E18B-8079 1 Fault Found: 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 4 Mileage: 201057 km Time Indication: 0 Date: 2000.00.00 Time: 23:17:03 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 842 B HW: 1Z0 920 842 B Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0F3813546 Shop #: WSC 00000 000 00000 VCID: 3663C05341B2A6AE7EF-8063 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 005 0943 Coding: 0000246 Shop #: WSC 73430 790 00000 VCID: 387FCE6B4BA650DE6C3-806D No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 L Component: EPS_ZFLS Kl.069 H07 1806 Shop #: WSC 02069 000 90108 VCID: 3467FA5B57CEB4BE40B-8061 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0202 Revision: 00020000 Serial number: 00000000000000 Coding: 00801A085283007F3F02850500084F01807C00 Shop #: WSC 73430 790 00000 VCID: 8305E987C2E04306091-80D6 Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted 1 Fault Found: 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 5 Mileage: 201057 km Time Indication: 0 Date: 2000.00.00 Time: 23:17:04 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 005 0943 Coding: 0000246 Shop #: WSC 73430 790 00000 VCID: 3979CB6F70AC49D693D-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 020 0041 Revision: 00020000 Serial number: SKZ7Z3H0143221 Coding: 0002400 Shop #: WSC 73430 790 00000 VCID: 2E53E833B9E29E6E36F-807B 1 Fault Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 005 0907 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 377DCD5746B85FA6659-8062 1 Fault Found: 01333 - Door Control Module; Rear Left (J388) 014 - Defective ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 005 0907 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 387FCE6B4BA650DE6C3-806D 1 Fault Found: 01334 - Door Control Module; Rear Right (J389) 014 - Defective ------------------------------------------------------------------------------- Address 77: Telephone Labels: 5P0-862-335.lbl Part No SW: 5P0 862 335 B HW: 5P0 862 335 B Component: FSE_2P5x H21 0060 Revision: 00000001 Serial number: 00000000519639 Coding: 0000466 Shop #: WSC 73430 790 00000 VCID: 326BFC43ADDABA8E527-8067 No fault code found. End ---------------------------------------------------------------------
