ZIDMAR
ZIDMAR's Achievements
  1. DOBRÝ DEN,PROSÍM O RADU OHLEDNĚ MÉ OCTÁVIE.MÁM OCT.2- 1.6MPI/75KW R.V.2005 A NAJETO 58000KM.MÁM PROBLÉMY SE STARTY.AUTO STARTUJE JAKO BY BEZ SYTIČE A PAK KLESNOU OTÁČKY AŽ SKORO NA 500 OTAČ/MIN. A MOTOR MI CHCE ZHASNOUT,VŽYDCKY MUSÍM PŘIDAT PLYN.2X SE MI OBJEVILA DOČASNÁ PORUCHA/ŘADA VÁLCŮ 1 SYSTÉM SEKUNDÁRNÍHO VZDUCHU 16875 P0491-PŘÍLIŠ MALÝ PRŮTOK /MÁM NOVÉ SVÍČKY,KABELY OK,A NA VAGU NENÍ ZOBRAZENA ŽÁDNÁ PORUCHA.NECHAL JSEM VYMĚNIT I ČIDLO CHLADÍCÍ KAPALINY.VZDUCH. KLAPA BYLA VYČIŠTĚNA.VŠE JE PRÝ OK,ALE AUTO STÁLE ŠPETNĚ STARTUJE.NĚKDY SICE NASTARTUJE DOBŘE ,ALE JINAK TO STOJÍ ZA PRD.V MRAZECH MI DOKONCE 2X NASTARTOVALO NA 3 VÁLCE.PROSÍM O RADU CO MÁM UDĚLAT.MOC DĚKUJI ZA VAŠE RADY.
  2. ZIDMAR
    Autopotahy MAD
    MÁM JE DVA MĚSÍCE,A JSOU SUPER.VELICE DOBRÁ KOMUNIKACE S VÝROBCEM ,AŽ NA TEN OBJEDNÁVACÍ FORMULÁŘ.VIDĚL JSEM UŽ LEPŠÍ.JINAK MÁM TU NEJLEVNĚJŠÍ VERZI,ALE KVALITE JE NA ÚROVNI.
  3. Jaký je postup při výměně svíček u Octavie2-1.6 mpi.
