marek.s
32 -
marek.s's Achievements
1
Ahojte, chcel by som sa opytat, kto by mi vedel pomoct s touto chybou na budikoch 1Z0 920 842 D. Dotycna osoba, ktora mi ich predavala, tvrdila, ze su nepouzite a nove, ale potom co som ich dal do auta pri starte blika par sekund "Error" a v diagnostike vidim: Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 842 D HW: 1Z0 920 842 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0D2620850 Coding: 0003101 Shop #: WSC 07790 995 07790 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 1 Mileage: 159257 km Time Indication: 0 Date: 2000.00.00 Time: 00:00:24 Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl Part No SW: 1Z0 920 842 D HW: 1Z0 920 842 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0D2620850 Shop #: WSC 07790 995 07790 2 Faults Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 1 Mileage: 69209 km Time Indication: 0 Date: 2000.00.00 Time: 00:20:35 00003 - Control Module 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Mileage: 216492 km Time Indication: 0 Date: 2000.00.00 Time: 17:24:48 zevraj toto vyskoci pri neodbornom prepalovani softu... a jedine prepalit nanovo pomoze... vedel by niekto, najlepsie z vychodneho slovenska, s tym nieco urobit? Dakujem
@marian.marcin: myslis ulozenie stabilizatora(to co je zalisovane) alebo gumy na tyckach stabilizatora? lebo namiesto: http://www.cc-autodily.cz/tyc-spojovaci-stabiliz-2_2?_fid=90d4 mi poslali: http://www.cc-autodily.cz/tyc-spojovaci ked sa vratim z dovolenky, tak odmontujem tyc stabilizatora a skusim rozhupat kolisku :), ale aj tak si zaobstaram original tycky, lebo tie 5Q... sa mi velmi nezdali...
xenony nemam :-(, skusil som to nahrat, mozno sa niekto s niecim podobnym uz stretol: https://drive.google.com/file/d/0B36R54GQbjqKdVlWTmFuNzYzSmx3cUhvS2Ixaklja09WYkM0/edit?usp=sharing https://drive.google.com/file/d/0B36R54GQbjqKYkxKQlBCQ3Z6b0JiVU9zN2UzZkV3X2RSQ3RZ/edit?usp=sharing zazrakom mi lava strana prestala vrzgat, ale zasa na vymenu si povedala prava, ze zacnem teraz ja. Mozu to byt pruziny(to sa mi velmi nezda)? Dakujem vopred za kazdu radu. Marek
@JerryJP75: tak to som si myslel aj ja, ze je slaba baterka, lenze zakupil som si presne taku istu baterku aku mas ty, ale zial robilo to stale - mozno nie az tak zle ako so starou baterkou, ale robilo. Po vymene startera - uz sa pri starte za tepla nezamyslam, ci nesedim nahodou v 120tke a budem natacat par sekund...
Zdravim expert vospolok :-), mam taky problemcek. Po vymene prednych tlmicov, pruzin, lozis a tyciek stabilizatora mi to trosku dost zacalo vrzgat na vodicovej strane ako nenaolejovana stara koliska. Je to dost neprijemne. Vrzga to aj ked rozhojdam predok auta. Mozu to byt loziska? Alebo tycky stabilizatora? Alebo samotna pruzina? Pouzil som: http://www.cc-autodily.cz/pruzina-predni-octav-2 http://www.cc-autodily.cz/tlumic-teleskop-predni-7_7 http://www.cc-autodily.cz/ulozeni-predniho-5 http://www.cc-autodily.cz/tyc-spojovaci Kazdy nazor, rada, postreh alebo skusenost velmi pomoze, lebo zamyslam vymenit predne pruziny od LESJÖFORS, ktore mam momentalne vzadu a mozno tie tycky stabilizatora. Neviem ci to nebude nakoniec samotny tlmic... alebo nebodaj lozisko. Hadam volba bilsteinov B4 nie je az taka zla. Dufam, ze nedospejem k tomu, ze budem musiet menit jednu vec za druhou a sledovat kedy to skonci :(... Dakujem Marek
Ahoj, tak nakoniec som vymenil starter, lebo ten stary mi aj dost vycerpaval baterku pri starte, cize software-ova uprava by pomohla, ale to, ze ten starter zatazuje baterku, nevyriesis tymto. Mal som moznost vymeny za novy starter a pomohlo, auto startuje ako nove a na prvu polotacku :D a vybuchy su prec, ziadne zatrasenie radiacej paky, nic . Mozno by bolo dobre pouzit kombinaciu - repas startera + soft uprava :D. Ale urcite chod do toho repasu startera. Malo by ti to pomoct. Marek
Za tepla mam aj ja velmi dlhe starty... je to dost otravne... Niektorym pomohlo vymena starteru, niektorym zvysenie davky. Ja by som chcel zvysit tu davku, zevraj sa to da cez VAG, ale netusim zatial ako... :)
ako to viem zistit? dost mi tie explozivne starty idu na nervy , uz to naozaj pripomina traktor...
hm, to si asi doma na kolene nespravim, ci? :) nebude to aj tou dvojhmotou?
Ahojte, chcel som sa opytat ci mate podobny problem. Ked startujem, tak motor naskoci doslova s vybusnym startom, cele auto sa zatrasie spolu s radiacou pakou. O2 2004/09 a ma najazdenych 158000 km. rozvody boli menene pri 120000km. dik Marek
ahoj, ani som to nechcel rozoberat dalej, len som chcel vyzdvihnut Tvoje kvality, to bol hlavny zamer... ak som nieco porusil, tak sa ospravedlnujem... tak ho aspon naserem :D , aby ten jeho ulovok nebol az tak jednoduchy...
@Jarda: este raz dodatocne takto verejne :-) by som sa Ti chcel podakovat za kvalitne, profesionalne a rychlo odvedenu pracicku. Som maximalne spokojny , este tie fotocky a uz nemam co vytknut :D @all: ak by som Vam mal niekoho odpurucit z ludi co tu maju svoje vlakna medzi "Vase prace / opravy - profici", tak silno mocno je to urcite Jarda , urcite bude spokojnost, kedze uz som mal skusenost este s istym nemenovanym panom, ktory vlastni jedno z vlakien a nedopadlo to najlepsie... Marek
tak sa len chcem uistit, ze volba 6Q0 945 511 je ta najlepsia... ze ci neexistuje novsie riesenie ;-), aby som zasa s tym o mesiac nemal problem...
Ahojte, chcel by som sa opytat, ci uz niekto z Vas riesil: Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 016 DJ HW: 028 101 188 3 Component: R4 1,9L EDC G000SG 6250 Revision: 12345678 Serial number: SKZ7Z0D2620850 Coding: 0000071 Shop #: WSC 73430 000 00000 1 Fault Found: 16955 - Brake Switch (F): Implausible Signal P0571 - 000 - - - Intermittent Freeze Frame: RPM: 798 /min Torque: 28.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.21 V Bin. Bits: 00101101 Torque: 152.0 Nm Bin. Bits: 0 01 0 Readiness: 0 0 0 0 0 ci mam uz vymenit ten vypinac? Lebo uz sa to objavuje pravidelne. Nasiel som, ze nahrada by mala byt 6Q0 945 511, ale to sa montovalo do roku 2006, mam 2004ku. Neviete mi poradit co tam dat kvalitnejsie? Dakujem Marek
Caute, chcel by som sa opytat na kvalitneho lakyrnika v Kosiciah a okoli? Potreboval by som nastriekat narazniky na O2. Dakujem Marek
