milosh
milosh's Achievements
  1. Ja by som chcel tiez vymenit budiky za Maxidot (O II Tour r.v. 2012). Podla toho co som sa docital, VCDS mi nebude stacit na to aby som to nakodoval (alebo ano?). Najde sa niekto v okoli NR kto by to vedel urobit?
  2. Vdaka za radu, uz to funguje! Skoda ze popis kodovania vo VCDS nesedi...ale to je jedno, hlavne ze to funguje.
  3. Potrebujem radu experta. Namontoval a nakodoval pomocou VAG zadny parkovaci asistent(FL) na OII Tour. Vsetko funguje bez problemov - akusticka signalizacia funguje aj radio sa stisi pri zaradeni spiatocky. Jedine co mi nefunguje je zobrazovanie na radiu Swing. Takto som to nakodoval pomocou VCDS (verzia 12.12): ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 5J0-919-475.clb Part No SW: 5J0 919 475 A HW: 5J0 919 475 A Component: PARKHILFE 4K H11 0005 Revision: --H11--- Serial number: 32961223600231 Coding: 00000E Shop #: WSC 12345 123 12345 ASAM Dataset: EV_EPHVA14SKxxx0000 001001 ROD: EV_EPHVA14SKxxx0000_SK35.rod VCID: 336F386E9AEFB980ECE ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb Part No SW: 7N0 907 530 M HW: 1K0 907 951 Component: J533 Gateway H42 1623 Revision: H42 Serial number: 220112F2000290 Coding: 352302 Shop #: WSC 73430 790 00098 VCID: 3A71154AB58548C82F8 ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb Part No SW: 1Z0 035 161 M HW: 1Z0 035 161 M Component: Radio-SWING 001 0003 Revision: -----03S Serial number: SKZ4Z2M1131407 Coding: 0B0004000001 Shop #: WSC 73430 790 00098 VCID: 38750F428B895AD8D9C Vie mi niekto poradit co som este zabodol urobit aby mi to na tom Swingu ukazovalo?
  4. Ale toto riesenie by mohlo znefunkcnit tempomat ... ak si stale bude mysliet ze spojka je stlacena tak sa nebude dat aktivovat.
  5. aj tu je o tom nieco pisane: http://www.skodaoctavia.cz/skoda-octavia/ovladac-zapinani-svetel-ze-superba-ii-do-octavie-ii
  6. Ten Climatic by mi asi stacil. Co obnasa prerabka na Climatic? Kolko tam toho treba vymenit?
  7. Zdravim, mam objednanu novu Octaviu a s hrozou som zistil ze namiesto Climatic-u tam zase montuju uplne mechanicku klimu ako pred 15timi rokmi. Nevie niekto poradit ci sa z toho da nejako zase urobit Climatic?
