problem s elektrikou
ahojte.mam taky problem s Octaviou 2 r.v.:2005 1,6 benzin ze ked nastartujem tak sa rozsvieti kontrolka ABS,ASR a potom zacne blikat aj kontrolka Brzd(cervena) aj to pipa.potom po cca 1az 2 minutach vypnem zapalovanie a znova nastartujem tak uz kontrolky neblikaju.auto ide normalne vykon ma.poradte prosim
VCDS Version: Release 908.0
Data version: 20090911
Saturday,01,November,2014,14:25:09:13314
Chassis Type: XXX
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: TMBCA21ZX62152996 Mileage: 158900km/98735miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Not registered 0011
Address 01: Engine Labels: Redir Fail!
Part No: 06A 906 033 FB
Component: SIMOS71 1.6l 2V 7004
Revision: --H01--- Serial number: SKZ7Z0E3118986
Coding: 0000071
Shop #: WSC 73430 790 00000
2 Faults Found:
28793 - No Communication with ABS Brake Control Module
U0121 - 009 - Open or Short to Ground - Intermittent
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00000001
Hex Value: 0x0000
RPM: 0 /min
Bin. Bits: 00000001
Hex Value: 0x0000
18327 - Load Signal from Alternator Term. DF: Short to Ground
P1919 - 007 - Short to Ground
Freeze Frame:
Voltage: 12.34 V
RPM: 0 /min
Duty Cycle: 99.6 %
Hex Value: 0x0002
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
1 Fault Found:
00003 - Control Module
014 - Defective - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1Z0 820 047 D
Component: Climatic PQ35 010 0301
Shop #: WSC 00000 000 00000
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003512665
Coding: 11040E011004140000110D000000000000197F0741
Shop #: WSC 29653 654 58047
Part No: 1Z1 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 29653
2 Faults Found:
02394 - Parking Light Left Front (M1)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 96
Mileage: 158438 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
ON
01259 - Fuel Pump Relay (J17)
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 254
Reset counter: 129
Mileage: 151746 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 11.95 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: Q2 AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0JXH9U
Coding: 0020786
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000012
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 810 B
Component: KOMBIINSTRUMENT VD1 3562
Coding: 0003101
Shop #: WSC 80093 222 69422
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001057248D99
Coding: 3D0F0300071302
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Reset counter: 89
Mileage: 151746 km
Time Indication: 0
Date: 2000.00.00
Time: 17:24:41
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 21
Reset counter: 129
Mileage: 158588 km
Time Indication: 0
Date: 2000.00.00
Time: 05:23:38
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3562
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2345
Coding: 0000244
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.0 D04 1606
1 Fault Found:
00625 - Vehicle Speed Signal
Freeze Frame:
Mileage: 8560 km
Temperature: 11.0°C
Voltage: 11.60 V
Voltage: 11.40 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AH
Component: KSG 0401
Coding: 00D002003F098505094B010004CC
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000244
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0034
Revision: 00019000 Serial number: SKZ7Z3G0140791
Coding: 0000200
1 Fault Found:
013 - Check DTC Memory - Intermittent
End ---------------------------------------------------------------------
