szyrma Odesláno Únor 9, 2012 Sdílet Odesláno Únor 9, 2012 Hoj kolega měl burku, a po opravě me svítí ABS, udělal jsem log (chyb jak máku) tak ho přikládám a prosím o rady Dík Chassis Type: 1U - Skoda Octavia I Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76 VIN: TMBBP41UX22605132 Mileage: 86610km/53816miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 038 906 012 CL Component: 1,9l R4 EDC 0000SG 3359 Coding: 00002 Shop #: WSC 31480 TMBBP41UX22605132 SKZ7Z0A1236147 5 Faults Found: 17971 - Quantity Adjuster (N146): Lower Limit Reached P1563 - 35-00 - - 17762 - Modulating Piston Movement Sensor (G149): Electrical Malfunction P1354 - 35-00 - - 17569 - Manifold Temp Sensor (G72): Open or Short to Plus P1161 - 35-00 - - 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - - 17655 - Needle Lift Sensor (G80): Open or Short to Plus P1247 - 35-00 - - Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl Part No: 1C0 907 379 K Component: ASR FRONT MK60 0103 Coding: 0021505 Shop #: WSC 31480 000 00000 3 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent 00285 - ABS Wheel Speed Sensor; Front Right (G45) 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 1C0 909 601 Component: 0F AIRBAG VW51 0004 Coding: 12358 Shop #: WSC 31480 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1U0-920-xxx-17.lbl Part No: 1U0 920 811 J Component: KOMBI+WEGFAHRSP VDO V11 Coding: 19112 Shop #: WSC 27049 TMBBP41UX22605132 SKZ7Z0A1236147 2 Faults Found: 01039 - Coolant Temperature Sensor (G2) 30-10 - Open or Short to Plus - Intermittent 01316 - ABS Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 27049 1 Fault Found: 01316 - ABS Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1C0-959-799.lbl Part No: 1C0 959 799 B Component: 45 Komfortgerát HLO 0003 Coding: 00259 Shop #: WSC 31480 Part No: 1U4959801D Component: 45 Tőrsteuer.FS KLO 0004 Part No: 1U4959802D Component: 45 Tőrsteuer.BF KLO 0004 Part No: 1U0959811D Component: 45 Tőrsteuer.HL KLO 0004 Part No: 1U0959812D Component: 45 Tőrsteuer.HR KLO 0004 No fault code found. End --------------------------------------------------------------------- 0 Citovat Odkaz ke komentáři
