jbakos90 Odesláno Červenec 1, 2013 Sdílet Odesláno Červenec 1, 2013 Ahoj všetci... po diagnostike auta octavia II 12/2007, 1,9tdi tam su 3 chyby. Vie to niekto identifikovať a poradiť ako tie chyby vyriesit? Ta ziarovka je OK svieti ale chybu sem tam zahlasi na pristrojovej doske, teda tam bude asi kontakt vo svetle alebo nieco ine? 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 03G 906 021 RH HW: 03G 906 021 AB Component: R4 1,9L EDC G000SG 1343 Revision: --H07--- Serial number: SKZ7Z0G4543889 Coding: 0000071 Shop #: WSC 62448 142 67566 VCID: 76E9F80101DC1C9 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0021121 Shop #: WSC 73430 790 00000 VCID: 73EFC11512AE091 1 Fault Found: 01309 - Power Steering Control Module (J500) 008 - Implausible Signal ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 S HW: 1Z0 907 044 S Component: ClimatronicPQ35 110 0402 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 468948C131BCCC9 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005233507 Coding: 11888F011004140000110D000000000000097F075C10000C000000000000 Shop #: WSC 80093 222 69422 VCID: 71E3CB1D68B23B1 Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 181007 022 0601 Coding: 00055223 Shop #: WSC 80093 1 Fault Found: 02395 - Parking Light Right Front (M3) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 142 Mileage: 202124 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 12.15 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA Component: Q2 AIRBAG VW8 027 0900 Revision: 11027000 Serial number: 003B5D139MBZ Coding: 0020786 Shop #: WSC 73430 790 00000 VCID: 6BDFD9754A9ED11 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC Component: Lenksäulenmodul 036 0070 Coding: 0000042 Shop #: WSC 73430 790 00000 VCID: 74EDC20917A00E9 1 Fault Found: 00883 - Ignition Switch (D) Terminal S 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 842 D HW: 1Z0 920 842 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4543889 Coding: 0001101 Shop #: WSC 29548 810 105258 VCID: 387536394B48AA9 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 161007F2001465 Coding: E9801F0E4006022302 Shop #: WSC 73430 790 00000 VCID: 30650E19A338729 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 842 D HW: 1Z0 920 842 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4543889 Shop #: WSC 00000 000 00000 VCID: 387536394B48AA9 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 1T0-919-887.lbl Part No SW: 1Z0 035 191 A HW: 1Z0 035 191 A Component: J401 0207 Revision: 00017000 Serial number: SKZ1Z2G7388376 Coding: 0013410 Shop #: WSC 73430 790 00000 VCID: 2F670D65BE066D1 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 006 1203 Coding: 0000116 Shop #: WSC 73430 790 00000 VCID: 387536394B48AA9 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 M Component: EPS_ZFLS Kl.069 H08 1901 Shop #: WSC 50679 142 84157 VCID: 356B3F0D5C5A571 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 CR HW: 1K0 959 433 CR Component: KSG PQ35 G2 044 0203 Revision: 00044000 Serial number: 00000000000000 Coding: 80801A485103007F3F04850500084B01803C00 Shop #: WSC 73430 790 00000 VCID: 820114D1DD14B09 Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 006 1203 Coding: 0000116 Shop #: WSC 73430 790 00000 VCID: 3973333D7042B31 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1T0-035-095.lbl Part No SW: 1Z0 035 191 A HW: 1Z0 035 191 A Component: R 0207 Revision: 00017000 Serial number: SKZ1Z2G7388376 Coding: 0013410 Shop #: WSC 73430 790 00000 VCID: 2F670D65BE066D1 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D7B272D646A8F1 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 5P0-862-335.lbl Part No SW: 1Z0 035 729 HW: 1Z0 035 729 Component: FSE_2P7x H24 0020 Revision: 00000001 Serial number: 00000000621222 Coding: 0000311 Shop #: WSC 73430 790 00000 VCID: F5EB7F0D9CDA971 No fault code found. End --------------------------------------------------------------------- 0 Citovat Odkaz ke komentáři
Hydraulik Odesláno Červenec 1, 2013 Sdílet Odesláno Červenec 1, 2013 zkus je prvně vymazat a počkej co naskočí znovu, a pak začít řešit 0 Citovat Odkaz ke komentáři
vevca Odesláno Červenec 1, 2013 Sdílet Odesláno Červenec 1, 2013 neodpojovals baterku? 0 Citovat Odkaz ke komentáři
jbakos90 Odesláno Červenec 1, 2013 Autor Sdílet Odesláno Červenec 1, 2013 mazat som uz mazal asi 3x..... vsetko naskoci automaticky. v skodovke povedali na jednu chybu ze to je pri octaviach normalne ze to netreba riesit, hmm mal som ho chut poslat do p***. baterku som ja neodpajal neviem ako vlastnik od koho som kupil auto, baterka tam je este povodna, ale teraz planujem kupit novu baterku. Co sa moze stat ak ju vymenim? treba nieco znovu nakodovat? radio som tu uz riesil minule nakolko nemam PIN na odblokovanie ale mi tvrdili ze to by sa nulovat nemalo. co stym? co to moze znamenat? 0 Citovat Odkaz ke komentáři
