Nesvítí pravý xenon
LadikRS
Snad nevadí, že zkusím štěstí tady, protože se jedná o Leona mk2. Ale chyby atd budou nejspíše totožné s O2. K problému, přestal svítit pravý xenon. Podezření jsem měl na vadnou jednotku xenonu, ale po napíchnutí na diagnostiku se obávám spíše problému v elektrice. Co myslíte?
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 209884 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        OFF
                    Voltage: 12.25 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 209884 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
00979 - Lamp for Low Beam; Right (M31)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01111010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 244
                    Mileage: 206441 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 244
                    Mileage: 210092 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:05:36
             Freeze Frame:
                    Voltage: 11.79 V
                    Speed: 0.0 km/h
                        ABS 1
02626 - Dynamic Cornering Light Motor; Right (V319)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 244
                    Mileage: 210092 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:05:36
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 209519 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:47:09
             Freeze Frame:
                    Voltage: 14.20 V
                    Speed: 0.0 km/h
                        ABS 1
02630 - Voltage Supply for Swivel Module Position Sensor; Right
            007 - Short to Ground - MIL ON
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 209519 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 05:47:09
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 5
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 10.93 V
                    Speed: 0.0 km/h
                        ABS 1
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 5
                    Time Indication: 0
02628 - Sensor for Swivel Module Position; Right
             Freeze Frame:
                    Fault Status: 11100111
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 244
                    Mileage: 203065 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:22:36
             Freeze Frame:
                    Voltage: 14.34 V
                    Speed: 57.2 km/h
                        ABS 1
             Freeze Frame:
                    Fault Priority: 3
                    Reset counter: 244
                    Mileage: 203065 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 10:22:36
02234 - Right Headlight Power Output Stage (J668)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 209884 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:05:09
             Freeze Frame:
                    Voltage: 11.08 V
                    Speed: 0.0 km/h
                        ABS 1
02233 - Left Headlight Power Output Stage (J667)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 209884 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:05:09
