Mam takovej mensi problem, kterej se mnou vlece uz skoro mesic, co jsem si vyzvedl auti po oprave. A sice nefunguje mi ovladani na kolebkach tempomatu a palubniho pocitace.
Auto bylo na diagnostice a vyjeli nasledujici chyby. Nicmene servis chce pokud by mel delat opravu prochazet jednotlive kabely vedeni, auto znovu rozebrat a slozit - tim padem mam byt cca 14 dni az 3 tydny zas bez auta... :(
Nenapada nekoho z vas, kde by mohl byt problem?
Auto bylo trefene na cumak s tim, ze byl venku komplet motor, vystrelene pytle a vse je vymeneno za nove. Za kazdou moznost, nebo nasmerovani budu vdecny.
At uz kde dal hledat, co diagnostikovat, nebo tak.
Aktualni vypis z VCDS:
Chassis Type: NE (5Q0)
Scan: 01 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F
VIN: TMBCJ7NE1F0245244 Mileage: 49694km-30878miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CKFC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 EA HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7546
Revision: 83H22---
Coding: 11190012032601091000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM20TDI01104L906021EA 002006
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 68D9DC8993D9ED0214-803C
1 Fault Found:
4714 - Steering Column Control Module
U0212 00 [039] - No Communications
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 49694 km
Date: 2016.12.06
Time: 07:47:55
Engine speed: 770.00 /min
Normed load value: 22.7 %
Vehicle speed: 0 km/h
Coolant temperature: 90 °C
Intake air temperature: 77 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.860 V
Unlearning counter according OBD: 40
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bit 0: 0
Cruise Control System (CCS): status-Bit 0: 7
CAN status - transmission control module-Bit 0: 0
CAN status - brake control module 1-Bit 0: 0
CAN status - brake control module 2-Bit 0: 0
selected gear-Bit 0: 0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 61085000000642
Coding: 1A076291242409710079070441C7295846249000E08294F200600070C006
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: 479B3F35FE07C27A3D-8012
1 Fault Found:
8277 - Databus
U1122 00 [009] - Implausible Message
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Date: 2016.12.06
Time: 07:47:55
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0367236394
Coding: 030C0C
Shop #: WSC 73430 790 00126
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A7D56C1BDF5AF92B2-806E
No fault code found.
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 L HW: 5E0 907 044 L
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 01010104002100011005004000101000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
VCID: 2E556A9171BD73321E-807A
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0137
Serial number: 01011512006545
Coding: 0C010A46424722FB47E04000000807080800000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_013.rod
VCID: 0009E4299BA93542BC-8054
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 150415 041 0570
Serial number: 150422090058
Coding: 065DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M05D05H03M49S38
Coding: 06885D
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 D HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0048
Revision: -------- Serial number: 39231511502916
Coding: 0001050001
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_SK25.rod
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0200
Revision: -------- Serial number: 003P4P7CMGE%
Coding: 98CCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F0B67D5E6574ABAC5-802A
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 454 000 804 15
Component: SideSensor_Df 008 0887
Serial number: 3576U0000007C6802415
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 454 000 904 15
Component: SideSensor_Pf 008 0887
Serial number: 3586U0000002EB502415
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 454 801 404 15
Component: SideSensor_Dr 111 0148
Serial number: 3516RE9F76506000000I
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 454 801 404 15
Component: SideSensor_Pr 111 0148
Serial number: 3526RC6F36506000000A
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 454 801 710 15
Component: FrontSensor_D 304 0149
Serial number: 3556VD2ADCD08000000Z
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 549 E HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 02121504720572
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_SK48.rod
VCID: 3E755AD1A1DD83B28E-806A
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5E0 920 741 HW: 5E0 920 741
Component: KOMBI 210 4290
Coding: 07AD0010A980000801081A001000000000000000
Shop #: WSC 73430 790 85294
ASAM Dataset: EV_DashBoardVDDMQBAB 009040
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 61CFC1AD70E39C4AD3-8034
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0003398560
Coding: 030000040F087300EF00024A080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72EDBEE1A50517D2BA-8026
Alternator:
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 5Q0 915 181 F HW: 5Q0 915 181 F
Component: J367-BDM H08 0223
Serial number: 52117L30354291958358
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00016.03.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_SK12.rod
VCID: 46853231F90DDB72C6-8012
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000104404004
Coding: 5500000000000000
Shop #: WSC 73430 031 00126
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 346178F99F9159E268-8060
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q4 959 393 C HW: 5Q4 959 393 B
Component: TSG FS 009 0015
Serial number: 0000147518776
Coding: 001401208000040000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43832B25CA3FEE5AE1-8016
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000005898155
Coding: 010200
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 0002
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 4587353DC40BD06ACF-8010
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q4 959 392 C HW: 5Q4 959 392 B
Component: TSG BFS 009 0015
Serial number: 0000147527990
Coding: 001401208C00040000001100
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428D2E21D525E752EA-8016
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000005916261
Coding: 190200
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 03EA00003F000000
Shop #: WSC 61872 002 1048576
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 40892429DB29F542FC-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5E0 035 867 A HW: 5E0 035 867 A
Component: MU-E--ER 820 6230
Serial number: 24031500010334
Coding: 03730100FF0000005011000100000000000000C40000810000
ASAM Dataset: EV_MUEnt4CGen2LGE 001017
ROD: EV_MUEnt4CGen2LGE_SK26.rod
VCID: 28599C8953592D02D4-807C
End-------------------------(Elapsed Time: 03:55)--------------------------
Vypis, ktery dostali v servisu, kdyz tam s tim bylo auto na prvni reklamacce:
Address 16: Steering wheel Labels: 5Q0-953-549.clb
Control Module Part Number: 5Q0 953 549 E HW: 5Q0 953 549 E
Component and/or Version: Lenks. Modul 003 0120
Software Coding: 0000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_SMLSKLOMQB 020001 (SK37)
3 Faults Found:
227339 - Windshield Wiper Switch
B1145 13 [024] - Open Circuit
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 154
Mileage: 48650 km
Date: 2016.11.29
Time: 15:17:51
Extended Freeze Frame Blinker Common: 2148 min
Extended Freeze Frame Blinker Common: 12.6 V
Extended Freeze Frame Blinker Common: 0 km/h
Extended Freeze Frame Blinker Common: 4.98 V
Extended Freeze Frame Blinker Common: not active
Extended Freeze Frame Blinker Common: 30
FF U Wischer AD value: 254
FF U Wish Wash AD value: 254
FF U Intervall Poti AD value: 255
FF U MFA AD value: 254
227355 - Windshield Wiper/Washer Switch
B1149 13 [024] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 154
Mileage: 48650 km
Date: 2016.11.29
Time: 15:17:51
227371 - Windshield Wiper Switch
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 154
Mileage: 48650 km
Date: 2016.11.29
Time: 15:17:51
