Zdravím, pomůže někdo rozluštit co s tím....
O2 1,6 MPI 2005 lpg
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No: 06A 906 033 FB
Component: SIMOS71 1.6l 2VG 9430
Revision: --H01--- Serial number: SKZ7Z0E3298383
Coding: 0000071
Shop #: WSC 56898 175 08206
7 Faults Found:
18528 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1: Too Lean
P2096 - 007 - Short to Ground - Intermittent
Freeze Frame:
RPM: 3040 /min
Mass Air / Rev.: 310.6 mg/str
Hex Value: 0x008F
Hex Value: 0x0088
RPM: 2752 /min
Mass Air / Rev.: 294.3 mg/str
Hex Value: 0x0090
Hex Value: 0x0088
18628 - Oxygen (Lambda) Sensor B1 S1: Signal too High (Rich)
P2196 - 006 - Short to Plus - Intermittent - MIL ON
Freeze Frame:
RPM: 3008 /min
(no units): 0.99
Voltage: 1.360 V
Voltage: 0.960 V
RPM: 640 /min
(no units): 0.99
Voltage: 1.720 V
Voltage: 0.960 V
16687 - Cylinder 3: Misfire Detected
P0303 - 009 - Open or Short to Ground - Intermittent
Freeze Frame:
RPM: 2176 /min
Mass Air / Rev.: 305.2 mg/str
Temperature: 73.5°C
Lambda: 0.0 %
RPM: 608 /min
Mass Air / Rev.: 119.9 mg/str
Temperature: 76.5°C
Lambda: 0.0 %
16686 - Cylinder 2: Misfire Detected
P0302 - 009 - Open or Short to Ground - Intermittent
Freeze Frame:
RPM: 640 /min
Mass Air / Rev.: 125.3 mg/str
Temperature: 60.0°C
Lambda: -30.1 %
RPM: 640 /min
Mass Air / Rev.: 109.0 mg/str
Temperature: 87.0°C
Lambda: -25.8 %
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 009 - Open or Short to Ground - Intermittent - MIL ON
Freeze Frame:
RPM: 640 /min
(no units): 0.0
(no units): 0.0
RPM: 640 /min
(no units): 0.0
(no units): 0.0
16556 - Fuel Trim; Bank 1: System Too Rich
P0172 - 007 - Short to Ground - Intermittent
Freeze Frame:
Speed: 72.4 km/h
Lambda Factor: 0.883
Voltage: 0.920 V
Lambda: -25.0 %
Speed: 20.1 km/h
Lambda Factor: 0.953
Voltage: 0.920 V
Lambda: -25.0 %
Freeze Frame:
Speed: 72.4 km/h
Voltage: 0.920 V
Lambda: -25.0 %
Speed: 20.1 km/h
Voltage: 0.920 V
Lambda: -25.0 %
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 73430 790 00000
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003743206
Coding: 118C0F030004140000110D000000000000087F075C
Part No: 1Z1 955 119 A
Component: Wischer SK351 012 0401
Coding: 00065525
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: Q2 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD02JLMO
Coding: 0020786
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1Z0 920 841 B
Component: KOMBIINSTRUMENT VD1 0918
Coding: 0003101
Shop #: WSC 10091 175 08206
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105B088810
Coding: 3D3F0340072302
1 Fault Found:
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 16
Reset counter: 254
Mileage: 153037 km
Time Indication: 0
Date: 2000.00.00
Time: 17:01:22
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VD1 0918
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2345
Coding: 0000244
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00D002007F2D8505084F010004CC
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000244
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 B HW: 1Z0 035 161 B
Component: Radio FO3 013 0029
Revision: 00013000 Serial number: SKZ7Z3E0049899
Coding: 0000200
Shop #: WSC 42404 123 91600
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2435
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
End ---------------------------------------------------------------------
