Lambda sonda
Rosvitila se mi kontrolka vyfukovych plynu. A diagnostika pise toto ( viz. Níze ) tak si myslim ze to bude na vymenu lamdy pred kat. Ale chci se zeptat jaky je rozdil lambd OII a OI stejne motorizace, jine koncovky? Hodil by se odkaz jakou koupit. Diky
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 HA
Component: SIMOS71 1.6l 2VG 1039
Revision: --H04--- Serial number: SKZ7Z0G4389582
Coding: 0004071
Shop #: WSC 73430 790 00000
VCID: 65C1571FAC941D36075-8030
2 Faults Found:
18675 - Oxygen (Lambda) Sensor B1 S1
P2243 - 006 - Reference Voltage Open Circuit - Intermittent
Freeze Frame:
RPM: 1344 /min
Mass Air / Rev.: 87.2 mg/str
Voltage: 0.000 V
Bin. Bits: 00000010
RPM: 2080 /min
Mass Air / Rev.: 234.4 mg/str
Voltage: 0.000 V
Bin. Bits: 00000010
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 007 - Performance too Low - Intermittent
Freeze Frame:
RPM: 1920 /min
Mass Air / Rev.: 114.5 mg/str
Resistance: 0.07 kOhm
Hex Value: 0x0002
Readiness: 0000 0000
Upraveno uživatelem Jirka313
