AFS xenony se nenataci
Guest hampl.ales
Guest hampl.ales
Dobry den, koupil jsem Octavii II s AFS xenonama, ale zjjistil jsem, ze se pri nastartovani provede pouze kalibrace dolu a nahoru, ale uz se nenatoci xenony do strany.
Kamarad mi VAGem vyjel chybove kody, ale bohuzel se nevyzna v kodovani.
Mohl by mi nekdo prosim poradit jak nakodovat xenony aby se i nataceli do stran? Dekuji
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 8388607
Shop #: WSC 00000 000 00000
VCID: 346C99262E53
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000023
Component: AFS-Lst.-Modul r 0005
Coding: 00000023
4 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Guest hampl.ales
Jednotka se musí dobře nakódovat, pak to začne pracovat, jak má
hmmmmmm :palec: :palec: :palec: :palec: :palec: :palec: :palec:
Pokud by nekdo potreboval, tak na DE foru jsem objevil reseni ktere me funguje.
Kodovani AFS jednotky zmenit na 1507354
Pak se udela zakladni nastaveni xenonu pres VAG v 55: Xenon Range
Basic Setting
[select]
[55 - Xenon Range]
[basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
Po tomto mi vse funguje a xenony se nataci jak pri kalibraci po zapnuti klicku, tak pri zataceni :)
Coding: 1507354
VCID: 346C99262E53
Coding: 00000023
Coding: 00000023
No fault code found.
  • o 4 roky později...
Ahoj klubaci. Mam podobny problem. Chyba nefunkcniho AFS. Nahoru i dolu se xenony pri startu auta nastavi. Chybova hlaska viz foto. Zkousel jsem vymenit vykonove jednotky na svetlech a projit vsechny pojistky. Bez vysledku. Kdyz jsem odpojil predni senzor na ramenu tak jina chyba nevyskocila. Dneska zkusim odpojit zadni jestli to napise neco dalsiho. Setkal se s tim nekdo nez zacnu utracet za novy senzory?
  • o 2 roky později...
