nespustenie AC u OII pri climatroniku s FL
Guest NahradneDielyTT
ahojte vsetci ktori mi mozete poradit.
Mam oct II. rv. 2005.dal som tam climatronik s OII.FL rv.2O10; vsetko mi funguje,klapky ok,zobrazuje sa mi na columbuse preste vsetko je ako ma byt. ale nezopne mi klimu. ked tam dam climatronik aky ma byt o octII. tak mi klimu normalne zopne a mrznem v aute. neviete mi s tym neako pomoct ako to dat dokopi? dakujem Vam.
Koupim jsem panel ktery byl novy a nebyl nakodovany.Kodovani jsem si vycetl od kamose z auta. Nakodoval a tlacitko AC bylo najednou funkcni.Kodovani viz screen.
Ale jeste jsem to nevyresil climatronic je dodelavanej a nechce se mi sepnout kompresor(jak na novej tak starej panel) diagnostika mi pise chybu buzeni kompresoru.Panel je zapojeny podle auta co ho melo.Na climatic klima normalne fungovala pritom sme to delali nejdriv u kamose tam to vsechno stacilo jen vymenit prepinovat a klima spina normalne.(jeho auto mr 07 moje mr 05)
  • o 3 roky později...
AC Compressor First Run-In
Necessary when the Climatronic control module (J255) is replaced.
Prerequisites to start the basic setting A/C compressor first run:
  • Engine at idle
  • Transmission in Park or Neutral
  • Do not cycle the ignition
  • Basic setting was performed for the flaps
  • Inside blower motor is switched on
  • Air vents fully open
  • Load management not active
"AC Compressor First Run-In" Steps:
Start engine and allow it to Idle.
Adapt flap end stops as described above.
[basic Settings - 04]
Select "Compressor Run In; Automatic Start" from the drop-down list.
  • It will show completed, but wait 120 sec (2 Min) and observe the flashing A/C button light on the HVAC panel.
  • After the Basic Settings has completed, the A/C light will quit flashing and the fault code will clear.
Note: If Basic Settings reports Error the module may need to see an Adaptation change before this can be completed. Go to Adaptation and change the Runtime (or Driving time) for "compressor run-in" basic setting from 120 -to- 120 and save it followed by repeating the procedure.
Takže abych to tak nějak shrnul.
Když mám MR05 s climatronicem (BJB) a chci dát panel z OIIFL, musím přepinovat konektory, nakódovat (i když nepoužiji úplně novou) a je to OK, nebo se musí měnit i gateway?
Neporadil by někdo, jak přesně přepinovat ty konektory? Který drát kam?
