Timil Posted January 30, 2015 Share Posted January 30, 2015 Zdravim budou pasovat kompletni brzdy z 1.8 tsi 312mm vcetne trmenu a tehlic na O2 ?? 0 Quote Link to comment
marekczek Posted January 30, 2015 Share Posted January 30, 2015 (edited) Jo Pokud mas na o2 55 tlumič tak ani tehlice měnit nemusis Edited January 30, 2015 by marekczek 0 Quote Link to comment
vevca Posted January 30, 2015 Share Posted January 30, 2015 přesně tak , na scoutovi už to máme cca rok a pul. 0 Quote Link to comment
lelko Posted January 31, 2015 Share Posted January 31, 2015 ahojte a viete mi poradit ci to sadne ked sa to meni komplet aj s otocom ? Tlmic mam 50 mm pred vymenou a chcem davat nove 55 mm ... bude to pouzitelne na 1,9 TDI ? 0 Quote Link to comment
ka_r_los Posted February 1, 2015 Share Posted February 1, 2015 (edited) http://www.sbazar.cz/Molda/detail/3438393-skoda-octavia-ii-rs-zadni-naprava-viz a nemáš co řešit... a předek už se tu řešil... Edited February 1, 2015 by ka_r_los 0 Quote Link to comment
duch Posted February 1, 2015 Share Posted February 1, 2015 http://www.sbazar.cz/Molda/detail/3438393-skoda-octavia-ii-rs-zadni-naprava-viz a nemáš co řešit... a předek už se tu řešil... to nejsou trmeny z rsa 0 Quote Link to comment
header009 Posted February 1, 2015 Share Posted February 1, 2015 tezko rict no ale RS melo vzdycky nejakou barvu bud stare meli zelene trmeny a nebo novejsi cervene. Pochybuju o tom ze by se to oloupalo ikdyz ten tvar cca sedi, spis bych to videl na nejakeho silnejsiho golfa 0 Quote Link to comment
marekczek Posted February 1, 2015 Share Posted February 1, 2015 http://www.sbazar.cz/protranscar/detail/5341047-vwskodaaudi-s3-brzdy-prestavbovy-set-z-288312mm 0 Quote Link to comment
ka_r_los Posted February 1, 2015 Share Posted February 1, 2015 Jen tam ještě chybí držák třmenu :/ 0 Quote Link to comment
Rolbař Posted February 2, 2015 Share Posted February 2, 2015 ten tam je... :) 0 Quote Link to comment
shamp1x Posted February 7, 2015 Share Posted February 7, 2015 To je komplet předek i zadek? 0 Quote Link to comment
marekczek Posted February 7, 2015 Share Posted February 7, 2015 Předek. Suprovy brzdy s kombinaci trw 0 Quote Link to comment
ka_r_los Posted February 7, 2015 Share Posted February 7, 2015 Ale plechy vidím 4... :) Jenže tady už jsou 17 kola minimum což? :) 0 Quote Link to comment
marekczek Posted February 7, 2015 Share Posted February 7, 2015 njn tak asi ilustrační foto či co :D bohužel jo no, v kombinaci s tím nižším podvozkem to je očistec pro záda po krásných hrbolatých českých cest. 0 Quote Link to comment
shamp1x Posted February 8, 2015 Share Posted February 8, 2015 A má smysl to dávat na sériový podvozek OII 2.0TDI r.v.2005? A jak jste psali výše, na 16 Vegy http://eshop.skoda-auto.com/cz/cs/b2c/kola-z-lehke-slitiny/kolo-z-lehke-slitiny-%E2%80%93-vega-6-5j-x-16%E2%80%9C/0/1/24/43/1001 to asi nedám co? :-D 0 Quote Link to comment
marian.marcin Posted February 8, 2015 Share Posted February 8, 2015 312 mm sa do 16" vojdu bez probl. 0 Quote Link to comment
shamp1x Posted February 8, 2015 Share Posted February 8, 2015 Tady tyto jsou ale 340, pokud se nepletu? 0 Quote Link to comment
marekczek Posted February 8, 2015 Share Posted February 8, 2015 jj 340 musíš mít fakt 17". jako upradovat z 288 na 312 za dobrou cenu proč ne, jinak to nemá asi smysl. má je tam v nabídce taky tuším. http://forum.octaviaclub.cz/index.php?app=core&module=attach§ion=attach&attach_rel_module=post&attach_id=158920 0 Quote Link to comment
shamp1x Posted February 8, 2015 Share Posted February 8, 2015 Vypadá to luxusně. Zatím mám brzdy relativně dobrý. Akorát hrozne práší. Až je budu měnit, tak o tom popremyslim. Hlavně aby ten upgrade sel. Plánuji na léto nějaké 17-18,v zimě ale ty 16, takže brzdy 312 max na předek? A co zadek? 0 Quote Link to comment
marekczek Posted February 8, 2015 Share Posted February 8, 2015 nevím co máš ted na zadku, ale asi bych to moc nehrotil... já ta mám 272 origoš co se dávali na 1.8, RS 2.0 TSI má 282.... 0 Quote Link to comment
shamp1x Posted February 8, 2015 Share Posted February 8, 2015 Budou tam nějaký sériovky. Asi to pořádně prostuduju až bude v dílně na jámě místo. 0 Quote Link to comment
marekczek Posted February 8, 2015 Share Posted February 8, 2015 a co mšá za motor? 0 Quote Link to comment
shamp1x Posted February 8, 2015 Share Posted February 8, 2015 Je to 2.0 TDI BKD r.v.2005 0 Quote Link to comment
marekczek Posted February 8, 2015 Share Posted February 8, 2015 tak tam je asi 260*12 0 Quote Link to comment
shamp1x Posted February 8, 2015 Share Posted February 8, 2015 Mám za to že to tak je, že jsem se o tom už s někým bavil. Předek tuším 288? a zadek ta 260 tka. Co tak přemýšlím o úpravách na autě, tak kdyby se mi to povedlo udělat všechno, bude to dražší jak nákupní cena auta :-D 0 Quote Link to comment
marekczek Posted February 8, 2015 Share Posted February 8, 2015 jj předek 288, to asi furt je stejný. 0 Quote Link to comment
pissi Posted May 11, 2017 Share Posted May 11, 2017 Zdravím pánové. Kdybych chtěl vyměnit 288čky za 312ctky tak musím měnit i brzdové třmeny,nebo by stačily jen držaky třmenů? Nevěděl by prosím vás někdo? 0 Quote Link to comment
marekczek Posted May 11, 2017 Share Posted May 11, 2017 pokud máš 288 tak stačí vyměnit kotouče, destičky a třmeny a držáky. ale být tebou už rovnou jdu do 340 či 345mm, protože 312 nejsou o moc lepší... 0 Quote Link to comment
pissi Posted May 11, 2017 Share Posted May 11, 2017 Budu dávat nové brzdy,tak jsem myslel,že bych vyměnil jen držáky třmenů a koupil hned 312 kotouče. Pokud je třeba měnit i třmeny tak na to prdím a dám 288. Dík za radu.. 0 Quote Link to comment
ka_r_los Posted May 11, 2017 Share Posted May 11, 2017 U 2.0 lze pouze výměna držáků třmenů, ale je to trošku složitější, budeš mít větší kotouč, ale nebude ti k němu odpovídat pístek třmenu a ten se u FL ESP koduje, takže je nebezpečí, že to pak bude brzdit trošku kousavě 0 Quote Link to comment
Recommended Posts
Join the conversation
